Torque Converter Advice for a Stock Truck...
Old Jul 31, 2009 | 05:25 PM
lq9crew's Avatar
Default Torque Converter Advice for a Stock Truck...
I'm thinking I'd like to get a converter for my truck. Only true mod is the tune.
It's an 06 Sierra, Crew cab, 4X4, with 6.0 LQ9, 4l70e, 4.10 gears, running 32 inch tires. It's big and it's heavy...
I'd like the converter to get off the line better, to lessen the rpm drop after an up shift, and to add some power where the next lower gear isn't an option. Going WOT when cruising between 35mph and 45mph is painful.
Anyone know what the stock stall speed of my converter is? It will brake stall to 2200, but seems to only flash to 1900ish when punched from a stop.
Is a 3000 too much for a stock truck that sees truck duties? (daily driving, towing, mild off road, etc).
Would a 3000 let me put a small cam in down the road without going to a higher stall?
I've been looking at the stock TB converters and the upgraded TBTC that Circle D sells.
Just looking for insight for a stockish truck, which I have not been able to find here by searching, SO MANY AWESOME TRUCKS HERE!
Old Jul 31, 2009 | 05:40 PM
sonoma43's Avatar
Yank 3k FTW!
Old Jul 31, 2009 | 05:42 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
A 3000 rpm stall is about right for a stock truck retaining good street behavior. You will definately want a good aftermarket trans fluid cooler. Sure, a 3000 is a good match with a smallish cam.
Old Jul 31, 2009 | 10:33 PM
call Chris at circle-d, nice guy, look at the 11" 278mm stall the have, i just bought one a2 weeks and am installing it as we speak
Old Aug 1, 2009 | 06:39 AM
Circle-D's Avatar
Former Vendor
I think out 278MM modified TB I6 would be a nice fit for you. It will bump your WOT RPM up like you want, but still maintain nice street manors. They are $375 for PTnet members. Shoot me a PM if interested or give me a call, be glad to answer any other questions you have.
Chris
TAPyvehc93
Jul 23, 2017 10:54 PM
BennyB
Aug 1, 2015 08:48 AM
KyleW707
Jul 29, 2015 08:17 AM
sauldgold
Jul 23, 2015 02:15 PM
JordanH
Jul 14, 2015 03:46 PM
