sway bar end links
ok i am going to invest in a rear sway bar soon, i am thinking about puting energy suspension sway bar links on the front sway bar. do you think this will help combined with rear
Assuming you have a 4WD truck, an easy mod to the front suspension is to install a front bar off of an SS or VHO truck (these bars are 1/8" bigger and about 60% stiffer than stock). The energy suspension pieces would be a great improvement too (Hotchkis kits use these parts).
You do need to do something to the front suspension, if you add a rear bar, otherwise you will change the "balance" - adding stiffness to the rear reduces understeer.
well i noticed that one of the bushings on the links was going bad so it has to be replaced. aanywhere i could pick up a ss or vho sway bar, i might add the addico one to the front too
GXPJAY
Nov 5, 2015 06:49 AM
maxspeed05V
Jul 19, 2015 07:08 PM
