so on my way to get my lq4..... (trans guys please look here)
so my engine builder said my engine stuff was all ready to pick up so jumped in my truck (04 2wd 1500 4l80e swapped) headed out for the 40 mile run was on the highway for about 35 miles everthing was good trans temp right about 130ish got off the highway and taking off from a light i herd a whine? started to listen while accelerating it was whining but just cruising no whine if it was i couldn't hear it? drove for a few miles pulled over to check the fluids trans level is a little high (fixed a leaky coolant line guess i over filled it) got back in the truck put it in drive took about maybe around 5 seconds to get in gear put it in reverse again about 4 or 5 seconds so put it back in drive again around 5 seconds when i started to move it felt gritty for maybe 15ft then normal since i was 2.5 miles from my engine builder i chanced getting there trans shifted fine temp gauge was still about 130/135 degrees fluid does not smell burnt but it is a grayish color not solid can see threw it
so i called my son to bring my trailer when i jumped in it after it sitting for about an hour or so to put it on the trailer when i put it in drive it was normal no hesitation or anything got it off the still felt normal? its cold out around 27 degrees so it cooled off but never really was all that hot
i was not beating on it or any thing i was cruising 70-80mph on the high way
any ideas on whats wrong?
1slow01Z71
04-26-2013 09:47 AM
ThunderZ28
14
06-03-2005 11:14 PM
