Shimming the circle D converter in 4l60e
has anybody got any advice on the easiest way to put the washer in between the torque converter and flywheel? Ain’t much space to work with and thought I’d reach out to the internet
Ok good. So Circle D sends with the converter three new bolts with two washers apiece, one thicker than the other. Should I use the thin or thick one?
Custm2500's Rude Friend
See this thread. https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/why-converter-clearance-535091/
Here’s how I did it. I had an extendable magnet I bought from O’reily, the on with the LED light. Popped it off and used it with another one and placed the magnets on either side of the bolt hole. Slide the washer in place at the bottom of the bell home and then rotated flywheel to the starter position. I took a harbor freight pick and heated it up to bend it around the flywheel so I could retrieve my magnets. Once I got all the washers and bolts in place I gauges it with a 1/8” drill bit. The 1/8” washer was tight. I hope this helps someone in the future
I don't think you know how to measure the clearance.
You measure the clearance with the converter all the way seated in the trans...not bolted up
If you installed those washers and didn't need them...you can kiss your pump goodbye...and maybe engine thrust bearing
