Dropping a 4x4 - ‘99 GMC RCSB
So I recently sold my 2002 1500HD because I don’t need that much truck anymore. However, I still needed A truck, so I went out scouting and picked up a 1999 GMC Sierra SLE - Single Cab, Short Bed, 4x4, 4.3L V6. It’s a bit rough around the edges, but for $500 it was a hard one to pass up. There’s no helping the V6’s [severe lack of] performance, but I’d at least like to make it look a bit sportier.
Now, I’ve owned over a dozen Squarebody and OBS trucks, and lowered quite a few of them. They’re easy to do and the ride always comes out nice, however, this will be my first dropped 4x4. I’ve been doing some research and there seems to be two main complaints - terrible ride or incurring bump steer. I’m not willing to live with either, but I’m not seeing many of the solutions being posted, granted most of the threads I’ve found here and other forums are close to a decade old. I’m not looking for a serious drop either, either 2/4 or 4/6. I would also like it to sit level.
The combo I’m currently considering is 2” Belltech spindles, 2002 Chevy 2500 Duramax keys (off my parts truck) and a 4” rear shackle kit with the rear axle block removed, if the truck has one. Possibly a flip kit, but from what I’ve seen the back always ends up lower than the front, and I’d prefer not to notch the frame if possible.
Has there been any new components released in the last few years that I should be looking at instead? Any better riding combos, or ones that don’t create bump steer issues? Also, at what drop point is a frame notch required, as I’ve seen mixed feedback on this? It’ll never see any towing, but I do haul around the occasional engine, transmission, or 4 wheeler, so I’d like to be able to carry 5-600 LBS in the bed without creating issues.
What’s all out there?
The spindles are good and will give you a 2in front drop. You don't need torsion bars if you want to go only that low of course.
The rear with the shackle and lift block gone should be a 3in rear drop.
A standard flip kit with the correct shackle will be a 4in rear drop I believe and you don't need a notch. Going to like 6-7in would probably want to really consider that notch so you don't bottom out the frame so easy.
I did a 2/4 drop with spindles and hangers/shackles, it looked good on my single cab long bed.
If you want to get rid of the torsion bars and go coilover.
https://atomicfabandperformance.com/
Atomic is active on here.
Alright, so I crawled underneath the truck last night to take a look at what’s underneath there. I do have the 2” block, so I can yard that out of there. However, I noticed my front spring hangers on the rear suspension are welded, not riveted. The hanger kits call out rivets, so what’s the deal here? Am I not able to do shackles and hangers on this truck? I really do not want to do a flip kit and C-notch.
Yeah, I think that’s the route I’m going to take - remove the blocks and add 2” shackles, and do 2” spindles in the front and see what that gets me. That’s still a 2/4, although not equal to the 2WD 2/4. This should still make the truck sit level, correct? If so, I can probably live with that height. Leaf springs would probably be insane to ship to Alaska, plus I’m sure their capacity would be less than stock.
lt4malibu
01-02-2013 08:24 AM
