Reuse Bearing with a TrueTrac swap?
bearings aren't that expensive, since you'll be installing a new differential you'll also need the carrier shim pack to ensure that it's spaced correctly, after all that you might as well spring for the 'master install kit' Installing gears is not something I do myself, so I made sure that I would have no problems with it when it was done the first time.
Resident Retard
A couple buddies of mine are going to help me install them, they are GM techs so they will be supervising besides I have always wanted to learn how to set them up. I guess I will price out some bearings, but I figured only 40k on factory bearing they should be fine... Anyone else use the bearing?
That's cool, the only thing scary about depending on reusing the bearings is if you mess one up removing it. If I remember right they are only about $10 each at the part store, might as well get new ones to save the trouble of even removing the old bearings.... that's just my opinion, but I'm kinda lazy sometimes and I don't have tools to press off the bearings without damaging them
Resident Retard
I wont be home till monday, but if your not in a hurry you can have everything for the price of shipping if its what you need..
