REQ: Pictures of Caltracs
the only pictures ive found are the blurry ones on their website. any help?
thanks, i think i may try and build my own set.
any other pics would help out greatly. |
there is a site somewhere that tells you the exact dimensions and everything you need to know to make your own set. ill see if i can find it
Yea, I was going to fab my own set but you cant mount your front eye-let plates outside of the front spring perch like those illustrations show.
Basically you will need to build them like that but you will need to swap in new front spring bushings to accept the 3/8" in plate your adding inside the perch. Also those rod ends aren't cheap. I think i was quoted like 115.00 for the ones i needed. +material and time its almost as much as they cost right from Calverts. However if you need any specific questions just let me know because i was VERY close to fabbing my own set up. |
hmmm can you also get me some pics of yours installed? that would be a HUGE help. ive got a couple weeks off and im going to try and make them.
ill try to grab some later on today!
that would be amazing, thanks!
where are my pictures! :kidding:
