replace a leaking trans cooler line part number?
hey all the lower trans cooler line on my truck is leaking from the crimped fitting, i cut the crimp off tried to put a hose clamp no luck still leaking much slower but its a leak
so i need to replace it, not big deal but i dont know what part number would be the right one for my truck? i swapped to a 4l80e a while back and just cut that hard line double flared them and extended them at the trans with some hose but since i need to replace it id like to just install the correct line for the 80e its the lower line at the radiator
any one know the right part number?
today i swapped the factory hose between the hard lines see if that holds me over till get the right one then install it when i swap engines
another thing is i have about 9k since i installed this trans in my truck i got it used, changed the filter and put new trans fluid when i put it in my truck and its dark already has me worried, its not black and burned but for less then 10k miles its dark grey'ish. I never seen trans temps over 190 when towing usually its runs between 140* and 160*
JeRM82
10-04-2016 10:54 PM
