Removing blocks under leafs?
Old Apr 13, 2005 | 09:11 PM
agreif's Avatar
Default Removing blocks under leafs?
Ok guys. Been looking around and have come across this option to remove the block between the leaf spring and the axle. Couple of questions about this though. The alignment of each way should be the same as the truck will move the same amount (assuming the drop for the block removal is the same as a shackle). I guess the shackle way would be a "body" drop and the other way would be a suspension.....I dunno, pretty much the same thing. Just heard of some people having vibes issues with the block removal, true? Does the shackle give me something that the block removal does not? I took a look underneath and only see a plate which the spring sit on, not a larger block like I expected to see. Is the block only on the 4WDs or something?
Andrew
Old Apr 13, 2005 | 09:18 PM
wkdivr's Avatar
The blocks are only on 4wd
Old Apr 13, 2005 | 09:24 PM
agreif's Avatar
So i have come to realize. Ok, I guess no free way to give me that 2" drop in the back then. Thanks.
Andrew
Old Apr 13, 2005 | 11:57 PM
thunder550's Avatar
High on diesel fumes
What would be involved in flipping the axle to the top of the springs? I've heard with some trucks it can be pretty simple, but I dunno about the GM's. If it's possible, that may be a quick way to get a drop in the back. Just an idea.
Old Apr 14, 2005 | 06:05 AM
SnakeOiler's Avatar
https://ls1tech.com/forums/showthread.php?t=292343
Read his article - he removed the blocks on his truck.
mikeyjm1
17
Oct 29, 2015 11:04 PM
kalikid06
20
Oct 13, 2015 07:37 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
69z-28
Sep 21, 2015 07:31 AM
