-   GM Drivetrain & Suspension (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/)
-   -   Rebuild front differential on AWD Escalade & Denali (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/rebuild-front-differential-awd-escalade-denali-490174/)
EscaladeEXT Oct 10, 2011 03:33 PM
Hello all,
Is there a good how to for rebuilding the front differential on an AWD Escalade or Denali? I have never done bearings and gears before. My truck has a howl from the front end and from what I have read I should be prepared to rebuild the diff.
Thanks in advance!
EscaladeEXT Oct 18, 2011 08:40 AM
Nobody has any input on this? Is this a dealer only thing?
jerrynaranjo08 Oct 18, 2011 11:16 PM
im looking for the same answer with no luck...my denali has a kinda knocking noise that i hear up front on the driver side...not sure if its my axle or diff....kinda sounds like if something is loose inside and is bouncing around as i accelerate and also as i stop??? any input??
budhayes3 Oct 19, 2011 01:07 PM
I don't know of anybody doing a write up on this, as I've searched also (same problem on my 99), but I have seen GM unit rebuild manuals on ebay for decent prices...
Bushby Feb 14, 2022 06:58 AM
I changed my ujoints and didn't quite put the drive shaft in the same way it came out, a year later it shook my rearend apart from vibrations. Vibrations will loosen your pinnion preload, then
https://cimg7.ibsrv.net/gimg/www.per...7d2ac04c72.jpg
your pinnion shaft will start thumping around and eventual end up breaking
