Would my setup benefit swapping 4.10s to 4.56 s?
I was tossing around the idea of swapping my 4.10s to 4.56s. My dyno graph shows I make power till about 6700 and I normally shift around 6900-7000 at the track. My track times are in my sig. Also my 60 ft should get a little better due to some recent tune adjustments.
Just curious what everyone thinks
either way 26 or 28 you still need gear to get to your powerband across the traps, so yes 4:56 gears would benefit you.. and if you cross the traps at 6k or below i would stick with the 28 inch slick but 26's should get the job done just gotta make them work.. it now becomes all in the suspension, putting the power to the ground is the hardest part, i run 4:88s with a 28" tire, quik kept telling me not to up the tire like most were saying, basically dont band aid the situation but correct it, basically since i was 4 linked make the 4 link work for what it is.. so i did even though i still slipped on the line ( need bead locks or screw rim to tire ) he made sense, i am now upping to a 29" tire only cause i run nitrous now..
