-   GM Drivetrain & Suspension (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/)
-   -   Rear end problems (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/rear-end-problems-503782/)
Ferocity02 Jun 25, 2012 01:28 PM
You're supposed to do a quick 30 minute drive at first, then let them cool completely. They get VERY hot on the first drive of break in.
BLUES MAN Jun 25, 2012 03:00 PM
Originally Posted by blackedoutchevy22 (Post 4945099)
And I did drive for about 3 hours straight almost 50 miles to break them in nothin hard jus drivin around then I took it on interste to go to scrappin the coast and got stuck in diamondhead with this problem
LOL that is a big no no, driving them with no cooling off period. Like stated above they need heat cycles the first time you break them in. Oh and your also supposed to keep it under 50 mph for the first 200 miles or so.
1FastBrick Jun 25, 2012 03:01 PM
Please read this article about proper break in procedure.
New Gear Break In
nonnieselman Jun 25, 2012 03:19 PM
heres what the paper work says for AAM gears pretty much.
"No burnouts, wheel stands, gas, nitro, drag radials or fun period.
Our paperwork says 200 `easy' miles. Do not pull a trailer or load
the truck for the first 500 miles"
The first heat cycle is the most critical.
Ferocity02 Jun 25, 2012 03:31 PM
I did a 30 min drive, about 15 miles with some stop and go, babied it and stayed under 55, then let it cool over night. Then did a 15 min drive got up to 65, let it cool over night. Then ~150 miles staying under 65 with approx 10 heat cycles. Then got up to 500 miles staying under 75. Need to change the break in oil this week and inspect the gears, but no strange noises so far. The gears are dead silent. I used Valvoline 75W-90 conventional.
Break in seems to be as important as setup.
silverado-lover Jun 25, 2012 06:15 PM
subbed
whitedakota Jun 25, 2012 08:38 PM
I just had a set of 4.56 USA standard gears and valuetrac put in my truck Wednesday. Me and a buddy did them. .040 pinion shim, .005 backlash. They are dead silent. Did the proper break in. I'm just shy of 400 miles. I highly doubt it's the gears either. I say bad install. We've put atleast 5-7 front and read sets in trucks in the 4.56 and 4.88 ratio. And all have been dead quiet. I use valvoline oil also fwiw.
blackedoutchevy22 Jun 25, 2012 09:10 PM
Yeah I did do the 20 min first drive around period and let it sit for almost 3-4 hours after then the next day drove it around the city for a good bit
TURBHOE Jun 26, 2012 04:39 AM
A friend of mine almost took his gears out after an install. The bearing set just past the diff body but he pressed them on, on a flat surface. So after a bit of driving the bearing settle all the way on and he lost the back lash.ucky for him he heard them soon enough and reshimmed. They have been good to go since.
skeet Jun 26, 2012 06:10 AM
gear swap head to track make quite a few passes load on trailer head home, no gear issues ;)
theyll break in and cool down during run time hahaha!
always ran USA standard gears!! setup my buddy up with my used gears no issues !
go figure
