-   GM Drivetrain & Suspension (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/)
-   -   pinion bolt/bearing pre-load specs? (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/pinion-bolt-bearing-pre-load-specs-506286/)
DrewSleeperSilverado Aug 15, 2012 05:02 PM
what are the turn torque specs on the rear pinion/bearing? I had DS high speed balanced by DriveShafts Unlimited in San Antonio & still getting a pretty high frequency vibration at 85-90 mph. haven't gone any faster than that. Could it be:
1) Not enough pre-loan on pinion bearings?
2) Are rear tires rotating faster than stock with the 4.10 gears (need to get tires re-balanced?)
3) Is it nec. to get a custom DS for 4.10's? have an alum 5" DR (stock)
:mad:
DrewSleeperSilverado Aug 16, 2012 11:22 AM
I can also hear a "wa wa wa wa" sound when im going anywhere from 60-80mph. didn't have any of these issues b4 the gear swap about 2wks ago.
Gadgetized Aug 16, 2012 10:39 PM
This is a real nice write up.
https://www.performancetrucks.net/fo...ll-how-460061/
On page 2 it states 14-19 inch pounds. If you tighten it too much, you need a new crush sleeve. It is easy to go too far. I do this torque measurement with the ring gear out.
DrewSleeperSilverado Aug 18, 2012 06:47 PM
just what i was looking for, thanks!
