Official A4 to M6 (T-56) Thread!
#103
The info I recieved form the dealer was 99-00, 01-02, 03-04, 05 up - these lines are all different. I ordered one for an 04 and it was really short but the Master was the same size. As I looked the Master I had gotten was leaking at the fitting so my friend used the old line and all the new gaskets and the pedl feels better. Not knowing BUT I think I have been sucking in air since the install. It will be rebled and I will let you know the outcome.
#104
Console Install
My frined and I finally got the new console installed Here are a few footnotes that he found that needs to be done:
- Remove the wiring harness from your lighter and 12 volt plug and replace it on the new console. This is if you bought one with the SUB from bose and the amp. Unless you have a BOSE I believe you can just plug and play.
- You must cut about 6' off the end of the BOSE sub box so you can see and work the shifter.
- Make sure you have it slid up towards the dsh so you have no gaps at the end.
_ You must purchase a glove box bezel ($200) Dealer or pray you can find one.
These are the issues I ran into with the install, I will keep you posted as to when my friend makes the adjustable rod for the factory master cylinder and the new perfect fit shifter rods to fit perfectly in the left side of the cup holder.
#106
Mount
Will post tomorrow, as to what it looks like now and then with the new stick once it is made. It had gotten dark on me.
#109
Originally Posted by nice_n_lo_silverado
All you need to do is bend that rod to the left a few inches and it will sit where you can retain the cupholders
