Official A4 to M6 (T-56) Thread!
#1081
This thread is very long. You would have to go back and go over everything.
I use the second tranny. GTO version. Deeper first gear because thats what I got and had the opportunity to get. Its is what I wanted too.
I use a 4.56 gear and 275 45 20 GTII Good Year Eagle.
I try and keep it between 1500 and 2000 rpms to keep the blue lights out.
You can change the reluctor somehow and get the speedo working correct. Never had a problem with the cruise not work.
You also can change the pulse per rev and that will correct the speedo.
#1082
Interestingly, seems like some people are using the T56's 17T reluctor without any issues also. It might just come down to proper tuning.
#1084
I couldnt say on sensor i saw complaints about cruise control not working etc. No one answered if they got it correct so i said **** it and went with what the truck came with.
My experience doing a auto to manual conversion on a 2001 2500 hd was the upper pedal support wasnt there which is kind of important i made the other bracket which in itself is a pita because it sits in a channel where it can slide down further i ended up bolting it down drilling a hole thru center and tacking it with my welder so it wouldnt fall down.
I intially ran it with out the upper pedal support but after seeing the whole thing flex a bunch i made something simple that bolted to the aluminum dash support to keep pedal from moving. big difference in clutch release height at least for me. I can post pics and videos if anyone interested
#1087
Just in case there are those with active subscriptions to this thread that otherwise don't presently monitor the forums, in another thread I am starting a conversation with Richard of Atomic Fabrication and Performance about creating a metal solution to the clutch pedal bracket problem (i.e. they break a lot and I'm tired of replacing them).
If you are curious or any at all interested, please see the thread here: https://www.performancetrucks.net/fo...lution-549097/
#1088
