-   GM Drivetrain & Suspension (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/)
-   -   OBS Silverado lowering question (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/obs-silverado-lowering-question-509349/)
stormgrey Oct 19, 2012 06:21 PM
OK I recently bought a 1995 silverado 2wd and it currently has a 3/4 drop on it. I want to make it a 5/8 drop so could I just buy 2" drop spindles and 4" drop leaf springs and be ok?? Of coarse I'll change shocks but opinions on if this will work ok. Side note the drop was on it when I bought it. Thanks in advance.
YenkoST Oct 19, 2012 08:29 PM
You will definately need to do a C-notch. The best course of action would be a flip kit and shackle or hanger to achieve your desired height. As far as the front, a 2" spindle would be the correct procedure.
stormgrey Oct 19, 2012 09:23 PM
The rear has a 2" hanger and 2" shackle already
PRO TOUR HOE Oct 19, 2012 10:39 PM
flip it the drop leafs ride like $h!t
stormgrey Oct 19, 2012 11:21 PM
So flip it with the lowing shackles and hangers??
YenkoST Oct 20, 2012 07:14 AM
Negative. Flip kit gives you about 6" so u will need to keep the hangers or shackles and take the other off to give you a total of 8".
stormgrey Oct 20, 2012 08:30 AM
Damn I was hoping I could get away with what I had. Not I've got to try and find stock hangers I guess.
stormgrey Oct 20, 2012 08:32 AM
Wait u said I could keep use stock shackles and keep lowering hangers. Because a buddy of mine has stock shackles.
YenkoST Oct 26, 2012 09:26 PM
Yeah...just adjust your pinion angle so find soem stock shackles and enjoy. Make sure your do a C notch.
iamkeniff Oct 27, 2012 04:10 AM
Might as well do control arms bc at 5" drop its gonna be a pita the align it
