New 4/6 drop, best way to fix the lean? Drop shackle?
Old 08-22-2017, 11:10 AM
Registered User
brandnewcolony's Avatar
Default New 4/6 drop, best way to fix the lean? Drop shackle?
Hey all,
Just upgraded my drop to a custom 4/6 kit that consist of the following:
Front
McG's 2" Spindles 17+
Belltech 2" drop springs
Belltech SP Shocks
Rear
Belltech 6" kit
C Notch
Flip Kit
Shock Extenders
Belltech SP Shocks
Truck current measurements are:
Driver Front- 27.5" Pass Front- 28.5"
Driver Rear- 28.5" Pass Rear- 29.5"
Whats the best route to go as far as fixing the Chevy Lean?
1" Drop Shackle on the Pass Rear?
Will that just fix the rear or the entire truck?
Thanks so much!
Old 08-22-2017, 12:25 PM
terravast4's Avatar
I did the shackle on mine and it sits pretty straight now
Old 08-22-2017, 01:04 PM
Registered User
Did you do a 1" drop shackle on the pass rear or a 1" lift shackle on the driver rear?
Old 08-22-2017, 01:41 PM
madmann26's Avatar
I did a coil spring spacer on my driver side front.
I'm getting ready to swap my leafs out and I'll be removing the spacer.
Old 08-22-2017, 01:51 PM
Registered User
I have the Belltech 2-3" drop springs set at 2" with the spacer on both sides so I can't add another spacer to fix the lean.
I could remove the spacer on the passenger side and do 1" drop shackles in the rear to get to a 5/7 drop but don't want to be that low.
Old 08-22-2017, 01:53 PM
Registered User
Basically does adjusting one corner of the truck with a drop shackle fix the lean for that whole side or just the corner?
Old 08-22-2017, 01:54 PM
ezdaar's Avatar
Go get a cpl of smurfs and make them stand on axle tube and lift the low side.
Old 08-23-2017, 12:11 PM
terravast4's Avatar
raise with one inch shackle on drivers side. It will correct all 4 corners. Mine looks even facing the front and facing the. Back
Old 08-23-2017, 02:17 PM
Registered User
Okay great! I ordered a Belltech 1" drop shackle for the pass rear.
Old 08-28-2017, 08:54 AM
S14serge's Avatar
So a 1" drop shackle vs a 2" drop shackle will fix the infamous Chevy lean?
