Need Help! rear end issues!
Old Mar 28, 2014 | 01:21 PM
khayslette2505's Avatar
Registered User
Default Need Help! rear end issues!
I had a stock rear end with 456 gears that gave out on me last night. I have a 08 Crew cab GMC with 572 rwhp with 35 inch mud tires and a built transmission, i need a heavy duty rear end now but not sure what to go with or where to get it.
Old Mar 28, 2014 | 05:36 PM
Try car-part.com and look for the 14 bolt rearend
Old Mar 30, 2014 | 10:32 AM
Jason Z69's Avatar
With that much power at a min a built 12 bolt. I would try a 14 bolt if u can find it.
Old Mar 30, 2014 | 07:17 PM
1FastBrick's Avatar
Custm2500's Rude Friend
4.56 Never came stock in these vehicles.
You can get a factory 14 bolt 9.5 that will bolt in and add the gears you want.
If you're breaking axles though, You will have the same problem with the 14 bolt.
Old Mar 30, 2014 | 07:25 PM
Registered User
I had the 4.56 gears installed in my stock rearend due to the lift and 35's, I knew the rearend was going to need to be replaced sooner or later, its the only part of the drivetrain that is stock. I've been trying to find a 14 bolt at the junk yards around but not having any luck
Old Mar 30, 2014 | 07:30 PM
Registered User
I priced a custom built 9" but it was 4k and would b 12 weeks before I would receive it due to them being busy. Not wanting to spend that much hoping I can get out of this situation for under 2,500 bucks
1FastBrick's Avatar
The Option Code is AXN and it was only available in the Vortec Max package. The early ones had a 6.0 that was later replaced by 6.2
Old Mar 30, 2014 | 07:32 PM
1FastBrick's Avatar
As mentioned try car-part .com
You should be able to find one. They go from $500-$1000
Old Apr 1, 2014 | 07:04 AM
axisT6's Avatar
Where are you looking? I can't touch an AXN (not that I want one) for less than $1200 + core around here.
OP, for $2500 you can build a 6 lug full floating 14 bolt and possibly have money left over.... With as much HP you have and big tires, I would opt to get away from semi floating axles.
Old Apr 1, 2014 | 09:17 AM
1FastBrick's Avatar
I'm in CA and they pop up on Craigs List from time to time for $500. I have seen them in AZ and TX on Craigslist for that price too. I stopped buying them.
I would rather have the 1500HD or 2500 light duty version and use the OBS 4x4 axle's.
pjb1972
Sep 17, 2015 02:06 PM
Oobray
Aug 12, 2015 10:56 AM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
Ketis
Jul 23, 2015 12:37 PM
