Much needed upgrade..
After I've hit the 400+hp mark.. Truck has been eating up flexplates (stock) after my stock one went out, I was told by friends to get a sfi flexplate, but I didn't have the money to spend on a good one. So I just replaced it with a other stock one.. Well 250 bucks later for a tow truck to get me off the interstate & back home. I should have listened to my buddy. 200 bucks for a flexplate ain't bad compared to the 250 for a tow truck & having to pull the transmission again. Seems like I just had it down last month.
Anyway guys, Don't take chances like I did, if your changing converters or transmissions, upgrade the flexplate too. I picked up a nice piece from Circle D. http://i1200.photobucket.com/albums/...r/1708add7.jpg |
nice piece, guess thats part of being hard headed right lol
Third times a charm - lol
Upgrading to an SFI Flexplate is a good idea. Worst case you wasted $150 bucks. Chris |
Originally Posted by skeet
(Post 4804833)
Nobody showed up for the party...
This is what I found. http://i1200.photobucket.com/albums/...r/0fe67238.jpg http://i1200.photobucket.com/albums/...r/ab56ae7e.jpg http://i1200.photobucket.com/albums/...r/d5f7a241.jpg Took out the rear cover & seal... Sucks to be hard headed sometimes :( |
Did it crack the rear cover?
OUCH! I plan on being over 400hp by spring and this wasnt on my list of things to swap out... Maybe I should consider this since Ill be getting my converter from Circle D.
Unless the cover is cracked you would probably be fine just changing the seal. Either away around, much needed upgrade and Chris has a nice piece there.
I've got two bolts in the crossmember, four in the bellhousing and the cooler lines are hose... I can have my trans out in about 30minutes :jest: Glad you're getting her back up and running man. |
Originally Posted by iamkeniff
(Post 4805242)
Originally Posted by silver-mod-o
(Post 4805273)
I've got two bolts in the crossmember, four in the bellhousing and the cooler lines are hose... I can have my trans out in about 30minutes :jest: Glad you're getting her back up and running man. I'm not that fast. Started @ 10 & was finished @ 2, with no lunch break |
