Misprint posssibly?
Old Sep 27, 2006 | 06:36 PM
blake2kz71's Avatar
Default Misprint posssibly?
I am going to order the detroit truetrac and 4.10 gears from summit. What else do i buy to replace everything else i need? Under recommended parts for the posi it says an install kit and 2 seperate bearings for some other rearend? Im kind of confused of what all i need to buy to install the gears and posi.
http://store.summitracing.com/partde...0+4294901322+0
Old Sep 27, 2006 | 07:42 PM
1SlowHoe's Avatar
Destroyer of Transmissions
You nees RAT-366K and you'll need some fluid. (assuming by your user name that you have a 2000 Z71)
If a shop is going to install the parts for you, then they will have the fluid. Just a thought. If you buy the parts and install them yourself you save a few bucks but, get no warranty. I bought my own parts and had a shop do the install and still got no warranty because I brought the parts in. So..if youre gonna have a shop do the install, price the total (all parts and labor) through them and see if its worth losing the warranty.
Old Sep 27, 2006 | 07:44 PM
Blown02Sierra's Avatar
it says 7.5 in. so i think it's for the front diff. of 4wd's. Ignore it. you do need that master install kit though. If you have never installed gears before i would reccomend taking it to a shop because they have the lash meters and know the correct torque, can install your crush sleeve correctly, everything.
Old Sep 28, 2006 | 09:37 AM
blake2kz71's Avatar
well it says on the page all the lockers are on 30 spline 8.5 gm 10 bolt, I dont know il just call detroit i guess. Me and 2 other guys will do the install. Im a machinist so i have all the tools.
Bret Kepner
Jul 22, 2009 02:34 AM
03tahoe22
Feb 26, 2009 12:50 AM
Scream
Feb 1, 2008 04:39 AM
Onyx 02
Nov 26, 2007 03:36 PM
1ImperialSS
32
Aug 7, 2006 11:22 AM
