| TURBHOE |
May 28, 2012 12:23 PM |
lower control arms questions
will 2wd lower control arms fit/work in place of 4wd lower arms? are they stamped steel or cast like the 4wd arms? also, will hd lower arms bolt in place of the 1500 4wd arms?
i want to try going to coil overs and get rid of the torsen bars. i see the d-max guys have done it WITH their 4wd INPLACE. so i figured i can too. but i would like to strengthen the lca shock mounting point. i figured if the steel type lowers would bolt in i could weld up what i need vise just bolting on a bracket to the cast.
yes, i understand that the shock location is different with the 2wd arms. but again if they are steel, i can put the mount where i want/need.
discuss.....:chug:
