locking 80e multi disc converter wot?
I have a circle d stage 3 258mm multi disc conveter with my 80e in my truck. Been doing some tuning trying to lock the converter wot in 3rd gear. I am manually locking it in 3rd and engaging the tcc with hptuners and from a 60 roll at wot it feels like it is slipping once the boost hits about 10psi. Pulls pretty good, but the rpm goes up faster than it should compared to the rate the speed goes up. Anyone else locking their converter? How does it react?
Look at the TCC slip in hptuners, that will tell you if its slipping...
Mine locks up hard and has zero slip in third or OD. I don't lock it up in third anymore, though. Just in OD.
I tried it last night for the first time. I set the lockup speed to about 10mph after 3rd gear full throttle. I saw the command in the scanner but I never felt it. :hmmm:
Originally Posted by smokeshow
(Post 4775396)
Originally Posted by 1989k1500
(Post 4775475)
in the turbo vehicles that I have been in, when the converter locks it pulls like craaazy. So I'm guessing yours didnt lock.
(Post 4775475)
Does this hold true in procharged apps? |
Originally Posted by jg53
(Post 4775490)
Hate to thread jack but I'm running the same converter in my truck.
Does this hold true in procharged apps? I think turbo stuff does it because it loads the turbo hard when it locks the converter. One I've been in a few times is a SS truck that trapped 127+ and the point that it pulled the hardest was from 100 and up because of the converter locking. It felt gained 200hp when the converter locked. |
(Post 4775503)
I have no idea. Never even ridden in anything with a Procharger.
(Post 4775503)
This issue is definitely something worth investigating with more and more people going the multi-disc lockup route. Maybe Chris at CDS will have some input. |
| All times are GMT -5. The time now is 03:25 AM. |
