-   GM Drivetrain & Suspension (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/)
-   -   LCA, UCA, and spindle combo (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/lca-uca-spindle-combo-287627/)
jus1975 Mar 9, 2005 04:26 PM
Are there any problems I should look for with 3" LCA and 2" spindles. I'm choosing this combo b/c I have an odd truck. It has torsion bar front end but 2wd. Some sites call them VHO's. What ever that means. Its a 2004 Sierra. I have 2" spindles with lowered keys know. I want to put the stock keys back and add LCA's. What do you guys think?
joesilver01 Mar 9, 2005 05:10 PM
Most Defenitely Go With A Spindle, But I Dont Think You Can Run That Combo. Even If It Will Work I Wouldnt Do It. You Will Run Into Some Querky Suspension Problems.
Stick With Those Dropped Keys And Then Use A Spindle.
jus1975 Mar 9, 2005 05:42 PM
But what if I want to go from 4" to 5" in the front. I would really like to do 5" in the front and I can't think of any other method.
jus1975 Mar 9, 2005 05:44 PM
I like the look of tucking the tire. I also have to figure out what size front tire to go with and that will match the rear stock Goodyears.
joesilver01 Mar 9, 2005 06:48 PM
I Just Think Using A Spindle And Control Arm Together Is A Bad Idea.... Torsion Keys Should Be Adjustable From 2" To 3" ......include That With A Spindle You Got 4" To 5" Of Drop.
jus1975 Mar 9, 2005 08:01 PM
The ones I got with the spindles are from McGaughy's. The guys their told me 1-2". Who has a 2-3"?
joesilver01 Mar 9, 2005 08:09 PM
Sorry my bad industry standard are 1 to 2 inch adjustable.
