help vette Servo ??????
Old May 14, 2007 | 08:25 PM
WhiteChevy3's Avatar
Default help vette Servo ??????
i cant get the new servo to silde into trans the big red rubber O ring is causing it to stop do i need to take it off and put the little black teflon o ring on instead????
Old May 14, 2007 | 08:26 PM
Phantom's Avatar
11 Second Club
you should use all o-rings and seals that come with the new servo
Old May 14, 2007 | 08:33 PM
it came with 2 little black rings and a blue one(for cover) i just cant get it to go in , the stock one only had one of the black rings on the servo this allowd it for easy in and out. im about to take off the rubber one and just use the little black teflon ring will this work?
Old May 14, 2007 | 08:39 PM
Phantom's Avatar
11 Second Club
no...
http://www.impalassforum.com/tech/dr...nsgo_servo.htm
Old May 14, 2007 | 08:58 PM
that one helped!
Old May 14, 2007 | 09:00 PM
how many Qts of fluid go back in? i changed my filter too?
Old May 14, 2007 | 09:04 PM
Phantom's Avatar
11 Second Club
5 maybe...i think thats what they tell you to put in when you do a shift kit...i.e. pulling the pan. but i wouldn't swear to it
Old May 15, 2007 | 05:36 AM
beastmode's Avatar
Import Moderator
im pretty sure your right
Wolftrk99
Dec 3, 2015 08:12 PM
Tigger Welder
Oct 1, 2015 08:41 AM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
lycominghunter
Aug 15, 2015 12:26 PM
bjamick
Aug 5, 2015 10:51 PM
