Help choosing dif gear ratio for my setup
Old 11-12-2018, 08:19 PM
Or I guess instead of a rear gear you could go with a bigger tire. Has to be room for more than a 28 inch tire.
Old 11-18-2018, 07:59 PM
400ss's Avatar
Did a little more work on the trans tune, shifting better, it did 12.5 on the 1/4 mile with the same 4.10 gear ratio but it does shift to 5th gear, not good, i got a 3.55 gear ratio from a friend and will try it, i may lock converter at WOT in 4th gear if needed, ill update you guys, thanks everyone
Old 11-19-2018, 07:05 AM
Hunt&Fisherator
silver-mod-o's Avatar
I wouldn't go any taller than a 3.73 on that setup and just raise your shift point and limiter, that Procharger wants RPM. Chances are 62-6300 is just getting to the good stuff. Let that thing swing to 6800-7K. You'll probably be faster and won't be shifting to OD at the top of the track.
Old 11-19-2018, 12:38 PM
400ss's Avatar
interesting, yes more rpm report more boost on my logs, my rpm limiter is at 6400rpm , stock can stock springs probably won't hold to 7rpm,
Old 11-19-2018, 01:52 PM
Hunt&Fisherator
I probably wouldn't do it on stock springs. It I've spun single PAC and Comp springs to 7K on "spring friendly" camshafts. Dual springs are a must with high lift and fast ramp rates though. The thing to do would be to put it on a dyno and see where your peak power is and shift it just past the peak, and gear/tire accordingly.
Old 11-19-2018, 08:41 PM
ZO6Ted's Avatar
I definitely wouldn't want to go to OD in the 1/4. I like wallaceracing.com for calculators. I like my 3.42's just fine so far.
400ss (11-20-2018)
Old 11-20-2018, 10:45 AM
400ss's Avatar
Hi man, i think i will upgrade cam/springs at same time , i did put it in a dyno and will do soon again, peak TQ was like at 5,000RPM and peak HP was at the higher RPM, the more RPM the MORE peak HP, it keep pushing more boost, i will upload pics of the dyno run. i just found a 3.73 gears ratio on my house, i will put those and upgrade rresults on thursday, i will go to the track, 3.73, and will keep it on 4th gear
Zeke2007
12-02-2010 09:12 PM
Lord Aries
01-23-2007 06:25 PM
1SlowFormula
11-06-2006 02:59 PM
stingragtiger
02-27-2006 11:21 AM
rgvsierra
24
01-17-2003 08:19 AM
Quick Reply: Help choosing dif gear ratio for my setup
