-   GM Drivetrain & Suspension (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/)
-   -   Good temperature port for 6l80e? (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/good-temperature-port-6l80e-499666/)
Birdman7389 Apr 1, 2012 02:41 PM
I have a cyberdyne digital temp guage that I'd like to install in my '10 Silverado with the 6l80E.
Anyone know if there is a port available on the trans, or am I going to need to splice into the hardlines when I install my Trucool 40k?
The temp sender is 1/8" NPT, FWIW. :burnout:
Birdman7389 Apr 4, 2012 02:51 PM
Anyone?
:help:
Starkey Apr 4, 2012 03:21 PM
Check this out..
https://www.performancetrucks.net/fo...stions-461890/
Did some googling and found that most people like to plug into the test port for their temp gauges.
Stark.
Birdman7389 Apr 4, 2012 03:51 PM
Thanks for the reply, but mine has the 6l80e.
Starkey Apr 4, 2012 04:04 PM
Yeah, I took that into consideration before hitting send :)
I figured if the 4L60e had a test port, the 6 does too.
edit: after some more googling, looks like buying a new pan with a bung welded in will be your best bet on the 6L.
Sorry for my ignorance!
Birdman7389 Apr 13, 2012 07:37 PM
Anyone?
Three6GMC Apr 13, 2012 09:36 PM
If the trans doesn't have a plug on the side like the older 4 speeds then I think getting a aftermarket oil pan or like you said tapping in after the trans cooler is gonna be your best bet.
