Gear Pattern advice
Gear Pattern advice
Im in the process of regearing my truck to 4.88 ratio.
Im working on the front 8.25 and wanted to post pics of my gear pattern.
Backlash set at 9
pinion shim .025
im thinking the pinion is alittle to deep
Backlash set at 9
pinion shim .025
There usa standard gear
Pattern falls into pinion too deep category
im going to decrease the pinion shim to .020
and tighten backlash a little
will post pics of new pattern
These are a little tight back off to .020 or even .015 to get your coast from being too deep.
pinion shim .020
backlash .008
I think this pattern looks like a good competition pattern
im probably going to run it unless one of you guys see something i dont
Looks good to me
let me know if i should run it with this pattern
give it a try try and see how it goes, I am a feel type person where I can tell by checking pattern and rotating forward and back to see how everything is meshing. I am doing this daily so it is hard to explain on type.
