A few basic shackle questions.
Old May 12, 2006 | 09:15 PM
jadaven's Avatar
good idea, I got under there this afternoon and i just said screw it for today...tomorrow I will put them on...I have the time then.
Old May 12, 2006 | 09:20 PM
TexCrew's Avatar
i got some.. its seems easy . a buddy told me it takes bout half an hour. my truck rides a lil stiffer. when i got it new( asks anybody with an 05) they ride spongy at first. now its stiffer. feels better on curves..the *** doesnt feel so light. i like the 2 inch drop fuctional yet lowered. check the sig.. here is a before pic
Old May 12, 2006 | 09:42 PM
00stepsyde's Avatar
it is very easy to do unless you have a stepside. I had to cut the factory bolts out to remove them. I also had a little bit of vibration with just the shackle. It was not real bad, just a little at around 60-70. I just was not happy with just the shackle and ended up doing a 3/4.
Old May 13, 2006 | 07:51 AM
02BlueStepside's Avatar
Like said above about the hitch, it will be in the way of the lower bolt. The method above should work, but the way I did it was to remove the bolts from the bumper and then the 2 rear most bolts on both sides. Then I loosened the front bolts and let the hitch rest on a jack stand. This gave me the clearence I needed and allowed me to put it back easily.
On stepsides, like said its a little harder. It has been a while, but I do remember having problems getting the top bolt out. I loosened the u-bolts holding the axle to the leaf spring and then pulled the leaf spring away enough to get the top bolt out.
calsdad
Jun 14, 2023 11:07 PM
thewrx
Oct 6, 2015 10:59 AM
JordanH
Oct 3, 2015 03:59 PM
BCraven1018
Oct 1, 2015 08:22 PM
OHsixLS3
Sep 25, 2015 04:38 PM
