Factory 2" body raise?
I have a 01 2500 suburban 4x4.
The last few times ive been in to order parts (at different stealer ships) the guys ask me if i have the factory 2" body raise... What the heck is that and how do i know if i have it. Im all about being 2" bigger LOL.... |
what it sounds like is like a factory body lift. you can tell by looking at the body mounts and seeing if you have a 2 inch block. well the best way to tell you what it looks like, it looks like a double stacked hocky puck on top of the rubber bushing.
I havent looked but i will. I know the hitch is flat against the bumper so im assuming it doesnt have a rase.
Then again a friend of mine has a 2500 HD truck and it sets higher stock than a 2500 NON HD. So maybe there is something different about them. |
the frame them selves are 2" taller from LD to HD, most likely you do have a taller frame, you can tell by how much frame hangs below.
Originally Posted by GMracer
(Post 3997900)
Thanks, Its pretty nasty. Has about everthing you can do, built motor, TH400, gearvendors od, 90MM turbo, nitorus, alcohol etc etc etc... custom made wide body...
I'm going to post it up for sale at some point... http://inlinethumb54.webshots.com/42...425x425Q85.jpg http://inlinethumb48.webshots.com/35...425x425Q85.jpg |
not to jump subject, but what motor do you have in it?
Originally Posted by chevytruck
(Post 3998100)
yea its 2JZ, or a 3.oL in line 6 stock. mine is 60 over so i guess that like a 3.1 or something.
the motors are pretty much bullit proof if you use your head. there are a lot of guy making 1000 wheel hp on stock parts. granted a cluch up grade and fuel system is required ( they die about 550 whp) quite a car to be as old as they are. Last year in the usa was 98. Actully had a shop interested in buy the shell to do a Twin turbo v8 swap. we could get together on a price, but if im not mistaken they where going to V8 it with the I force out of a tundra and then run twin 60 mm turbos.. |
