Cognito/kryptonite pitman and idler supports with large sway bar?
4L80 is about done and while the truck was at the trans shop I noticed my idler arm looks pretty rough. I suspect all my steering is original, so I plan to replace worn bits and upgrade the steering where I can.
Plan is to do moog idler and pitman arms, kryptonite death grip idler support, kryptonite tie rods, and I was thinking about going overkill and adding in the pitman and idler support braces.
I noticed the the older version of these included sway bar spacers. I run djm bars and have seen some complaints about clearance issues that reduce steering range. Plus some comments about limited thread engagement with the shank nuts they use.
Anyone able to run these with aftermarket sway bars without a spacer? Opinions?
truck is a 2003 SS on stock ss wheels.
C-WAY
04-14-2011 10:11 AM
TX Tahoe Z71
02-24-2010 10:34 AM
