centerlines correct offset?
i found that centerline wheels is selling the stingray III's 20" x 8.5 6x5.5 for $159 each. the it says for gm trucks and suvs. the offset says 5.4 , i wasnt sure if this is correct or not. if thats the case, im pick me u some wheels. 20" stingrays for 760 or so shipped.
That's what I bought and they said they would fit, so we will see. The only bad part is they are on a 4 week lead time. This week will be week 4 for me...so hopefully they come in this week or next as I am going CRAZY!!
They are a good offset to run. I've had my 20x8.5" Centerlines for almost a year now with the same offset without issue. Mine are the RF Zoom wheels with a 275/45/20 Yoko tire.
The wheels you are talking about are the "Ultra" series, which are new. Same wheel, alot lighter! The reg. Stingrays had a 5.0" backspacing, so these should be a little more under the truck than the older ones. I don't see how you can go wrong for $750 shipped. I've heard the wheels weigh 19lbs each, which is about 8lbs less per wheel than the older "non-Ultra" version.
Originally Posted by Colby 04
I got mine last week
I waited a little over 3 weeks for mine. They weigh under 20lbs each and right at 56lbs with yoko 275/45/20 tires.
6x55, body, centerline, centerlines, lead, lightweight, motorsports, offset, rapid, rim, stingrays, throttle, time, vmax, wheels, zoom
