Caltracs vs Long Bars
I dont know if this is stupid or not, but can you put both on a truck? :confused: Or would the caltracs have no purpose with the long bars in place? Sorry, lol, just throwing some ideas since i have nothing to do at work. :emb:
they are both the same thing, just set up differently.
ah ok thanks!
Originally Posted by built408
(Post 3986945)
a caltrac is basically a really fancy pinion snubber because it uses the front spring perch as a pivot point, long bars on the other hand use a much longer leverage arm to lift the front of the truck up and transfer the weight to the back tire, the caltracs don't really do shit for weight transfer but they keep the wheel hop out cause they prevent your leaf springs from looking like this under load ~ caltracs have a habit of actually lifting the rear end under load instead of squatting |
Originally Posted by ZZebes
(Post 3986972)
Not exactly
a caltrac is basically a really fancy pinion snubber because it uses the front spring perch as a pivot point, long bars on the other hand use a much longer leverage arm to lift the front of the truck up and transfer the weight to the back tire, the caltracs don't really do shit for weight transfer but they keep the wheel hop out cause they prevent your leaf springs from looking like this under load ~ caltracs have a habit of actually lifting the rear end under load instead of squatting Actually the Caltracs move your instant center much farther forward than just using the leaf spring . If your having problems with to much separation you need to stiffen the shock extension. Caltracs are just a crude 4 link, but they do wonders for weight transfer. while keeping the leafs from wrapping up at the same time. you do need to have a minimum of 5" of front end travel to get the most out of them though and the looser the better for a truck. |
So does the front and rear have to be loose or just the front?
Originally Posted by Dirty 30
(Post 3986976)
Originally Posted by MR Marine
(Post 3986975)
Originally Posted by vanillagorilla
(Post 3987431)
I keep hearing this, but nobody has said if it's 5" total or not. In other words, at the starting with the vehicle at ride height, do you need 5" of travel downward? Or do you just need the front suspension to travel 5" total, like 2.5" down and 2.5" up?
So in the end are long bars or caltracs better or does it depend on the situation.
