Caltracs street vs track (Videos & Pictures)
#31
is that an et drag, or et drag radial? the pics look like a radial. most people seem to hook best around 17-22 psi on the et drag radial. i did best at 18 psi.
photobucket sucks ***. do you have a youtube account? id like to see a non choppy slow mo and full speed video. the choppy video is hard to tell but it looks like it tried to hook, then unloaded. thats where a double adjustable shock comes in handy. you can leave the separation loose as for the initial hit, and firm up the compression to keep the tire planted.
if you hooked 6/7 passes you're close. i would tighten the shocks one click and evaluate the tire pressure you're running (if that's the drag radial). dont change both at the same time. that's according to the crappy *** video that chops around.
#34
seemed like it would hook great at 5psi but the one time i did more it spun the tire so i need to figure out why
so more tire pressure and 1 click on the shocks? (position 6) would you leave the bars as they are?
#36
it doesnt look like you hit the tire that hard at all to me. do you have a video of your truck staging up? it tried to hook and unloaded. i would try tightening the shock a click or two to see what it does. if it messes it up, loosen it. that fine line will be harder to find with a single adjustable shock but it's been done.
also, i know you turbo guys have to give it rpm to spool up which could take away from the antisquat. i never had to deal with that on N/A and nitrous setups.
#37
iŽll try tightin the shocks a little next time
what would help more to put better shocks in the front or change these ranchos for better ones on the rear lets say i just wanted to go one or another for now?
#38
the front actually looked like it did what it was supposed to. check out what settings other rcsb trucks are running. foose04 would be a good start. i wouldnt give up on the ranco just yet, but a DA shock is the way to go IMO. the first pass in my s10 was a 2.0 60'. my last pass in the s10 was a 1.46....i didnt touch a single thing on the truck except for shock and bar settings.
#39
