caltracs with 2inch hangers?
Just want to make sure that there wont be a problem putting them on with lowering hangers. there Beltech (spelling?) hangers if it makes a difference. Thanks
i have mcgaughy hangers with two positions , iirc i had to use the higher setting or the bottom hole on the hanger in order to use them . this was a while back though and i did it becasue i only wanted a 3" rear drop and used a 2" shackle . i previously had it set the opposite way before and had a bad pinion angle . i want to drop it a bit more and will find out what it takes to make them go in the lower setting.
i know most hangers only have one setting , 2" and thats why most will work fine.
FlowmasterMufflers
09-18-2015 02:31 PM
