? for BFG AT KO owners
Is anybody else having noise and vibration problems with these tires.
I've been having a vibration in the steering wheel (on left turns only) for a while now. Last year I had the RH wheel hub/bearing replaced under warranty for this problem, it didn't seem to help. This spring I replaced the LH hub, still no change (it did fix the rumble,rumble noise at low speed). Today I took the RH hub off to see if it was bad again, but its ok. So anyways, I thought back, and eveytime I rotated the tires, it would get worse, but it only does it turning left. So I put my spare tire on the RF, and the vibration is gone. I can't figure out why it only does it the one way, I've balanced the tires, and rotated them all different ways. I use to like these tires, the tractson is great, and they look good, but there noisy, and ride rough. The tires are 1.5 years old, 40000-50000 kms. Tread is 60-80%. |
Not sure if this has anything to do with it but my BFG's are rotational. If you mounted one to rotate the wrong way that would probably cause a problem and tire damage and a blow out eventually. When I was first mounting mine I put one on wrong, a guy walked by and pointed it out. Easy mistake to make if youre in a hurry.
I have been noticing a little more noise with my BFG's than I used to (humming at about 35-50mph)...I also noticed that the sidewall on one of em is starting to ripple a little bit. As far as vibration goes, mine definitely need a good roadforce balance, it vibrates between 65-75mph...although I had the same issue with the Firestone's that came on it (had em all roadforce balanced and it was smooth as butter)
Sweet truck BTW! |
Had my 22" BFG's force balanced and they were much smoother, the 24" BFG's were balanced the old fashioned way and I haven't had any problems. Every tire is different I guess.
I got 55k+ miles on the first set with no prob. (285's),working on the 2nd set (265's) w/ about 10k mi. currently.
No tire problems, but I have had my "steering shaft" replaced (twice), and greased a couple of times by the dealer. |
Good tires IMO I had mud terrains on before my goodyears and loved them never had a problem with balancing them. To me it sounds like you may have a bulge in one of the tires I have never had a problem like you are tlaking about.
