-   GM Drivetrain & Suspension (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/)
-   -   Best rear gear and brand (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/best-rear-gear-brand-538680/)
USMCvet0311 Jul 14, 2015 10:42 PM
Building a 370 and am stuck between a 373 or 410 rear gear. Also, what brand? Setup will be daily driven with a weekend here and there at the track. Let's hear those opinions.
GMCtrk Jul 14, 2015 10:43 PM
AAM if you can get them
George C.... Jul 14, 2015 10:47 PM
gear will depend on entire setup
ive had luck with motive and OEM
USMCvet0311 Jul 14, 2015 11:23 PM
370 with flat top Pistons, L92 heads, L92 intake. Upgraded 4l60 (until it destroys itself). Eventually a 200 shot.
USMCvet0311 Jul 14, 2015 11:25 PM
Wheels and tires setup: 20 inch decladded wheels and tires are 255/50/20
George C.... Jul 15, 2015 08:56 AM
what tires for strip? 30" tire is alot of tire to race with unless you have power
also what are cam specs? what is converter size
if you want full potential from truck you will need a lower gear then 410
USMCvet0311 Jul 15, 2015 11:53 AM
I'll be using a set of factory 17's stretched as a drag wheel. Probably end up with a 28 or 29 inch tire.
George C.... Jul 15, 2015 11:55 AM
If 28s then 430s are good all around
Now if more race 456-488
If I ever build a NA truck again it will have gear for sure
Hell my daily has 488s but does have 35s
USMCvet0311 Jul 15, 2015 12:45 PM
I appreciate the info brother. I'll probably go with a 430
TimDave217 Jul 21, 2015 01:06 PM
I've always said a 4.10 or 3.73 is a good gear for dailys. And I've always used oem gears, powertorque from oreilys is what I've used in past gear swaps and they have done great. He'll I've got a bnib set of there 3.73's sitting at home that I need to get rid of! I've also heard good things about motive and there prices are decent.
