Axle bearings or new axle...
Made in South Korea
My axle bearing onthe driver side has 1/8" of play... New junk yard axle or new bearings.
Facts I have 3.23 g80 10 bolt so it's crap
Try and find a 3.73 g80 10 bolt for $300-400?
Both, except not.
New axles & new bearings.
The axle IS the inner race of the bearing. If either one is fornicated, BOTH are. There is NOTHING DUMBER than swapping one out but re-using the other. Kinda like putting new bearings into a motor but leaving the DESTROYED crank in it untouched... pretty much a recipe for a Pete and Repete.
It takes only a few minutes to swap out axles; probably less than an hour, counting jacking up the car, and a few applications of technician attitude adjustment fluid. New axles & new bearings will come out in the same $300-400 kind of range, but are MUCH faster and eeeeezier. Plus, with a junk rear, you still have stock axles (JUNK to begin with), and used bearings, all with however many miles on them.
Why "G80"? See photos of acoupla those here. https://www.performancetrucks.net/fo...d-slip-555136/
Axle saver bearings are only to get you home when you are traveling and lose a wheel bearing, or keep you going while you locate a new rear end. With 1/8 inch of play, it's likely that the entire rear end is full of powdered axle metal. If you drain the oil and it looks like straight anti-seize, the rear end is probably ruined from the abrasive qualities of the metal dust. It will ruin all of the other bearings and polish the gears to a dull, rounded condition.
Tootall
37
10-20-2007 12:57 AM
