Tahoe/Yukon: T/A or Moser 10-bolt Diff cover
Did a search but couldn't fand anything specific.
Has anyone installed a T/A Performance or Moser diff cover on the 01-03 Tahoe or Yukon? Does it clear the panhard rod? Don't want to purchase then have it not fit...
If the Moser cover does not have carrier preload bolts like the T/A cover, then get the T/A. If the Moser does have the carrier preload bolts and it is the same price, then I would still go with the T/A (because of T/A's reputation). The only instance where I would go with the Moser is if it is cheaper.
Most any diff cover will give you added torsional rigidity, but only a couple preload the carrier, and the stock 10-bolt/8.6" rear needs all the help it can get.
That's the problem I had with the Avalanche, there was only an inch between the stock diff cover and the panhard bar. Right around the time I was selling the Avalanche, T/A came out with a newer cover that was lower profile than their regular cover for the 8.6" 10-bolt. I never got a chance to try it because I sold the vehicle. But you may want to call them and see if it would work in your application. By now they may know for sure what vehicles it works on (like ours with the 5-link). Also, you can only get this low-profile cover directly through them - none of their distributors carry it.
Good luck and let us know how it turns out.
That's the problem I had with the Avalanche, there was only an inch between the stock diff cover and the panhard bar. Right around the time I was selling the Avalanche, T/A came out with a newer cover that was lower profile than their regular cover for the 8.6" 10-bolt. I never got a chance to try it because I sold the vehicle. But you may want to call them and see if it would work in your application. By now they may know for sure what vehicles it works on (like ours with the 5-link). Also, you can only get this low-profile cover directly through them - none of their distributors carry it. Good luck and let us know how it turns out.
gmcyukon
10-03-2015 11:03 PM
KINGCYCLES
10-02-2015 10:21 AM
