Another servo question???
I have done a search and still have a few questions.
First is how to install an OD servo. I have read the corvette servo but I can't seem to find out much info on the OD install. Second is, on Ebay one of the corvette servo kits comes with a longer pin. Is this something that is worth the extra money and does it change the install any. any and all help will be much appreciated. Thanks Kyle |
The 2nd gear and 4th gear servos are mounted on the same pin and the unit is removed as a whole. You must removed the OD servo in order to replace the 2nd servo.
Yea its pretty straight forward. Once you remove the OD servo cover, you can pull out the whole pin assembly. Heres a pic of the old vs new servos.
Left side is vette servo and billet OD servo and right are the stock servos. http://i3.photobucket.com/albums/y73...e/IMG_0705.jpg And here is a pic of the new servos installed. http://i3.photobucket.com/albums/y73...e/IMG_0713.jpg |
Thanks for the replies. What about the longer pin. Has anyone used one or is it
not needed. Thanks Kyle |
