aluminum control arms and aluminum spindle from 2014-2018 1500
has anyone tried putting aluminum spindles, upper and lower control arms from a 2014 Silverado/Sierra on their 2007-2013? some places specify that their control arms will fit 2007-2018 Silverado/Sierra. would be cool if there was an easy way to drop some weight from the front end.
The other thing I do is see if any companies list parts that show to fit both, in the description. So I went to DJM and their upper and lower control arm kit, shows to fit 2008-2015. Im not sure why they didn't put 2007-2018, but I do see this alot where they for some reason don't include all years. However, if you have a 2008 or a 2015 the kit is the same from DJM. Which is another indicator the parts are interchangeable between the trucks.
https://djmsuspension.com/product/20...-control-arms/
I've been under the impression the frame is the same on the GMT900 and K2, as a technician everything I touched looked the same but google says they aren't the same... so I don't know.
So, it looks like you can put 14+ components on your GMT900. You just need to make sure you match up which parts work with each other. And the simplest way to say it is, it's all the aluminum stuff goes together and the steel stuff goes together.
eallanboggs
Aug 19, 2007 05:58 PM
eallanboggs
Mar 22, 2007 01:31 PM
