9.5 hybrid vs 8.6 for towing
So ive got a 9.5 hybrid here from a vortec max nnbs and my 10 bolt needs some 4.88's bad. Ive got 36" tires and tow around 5500-6000lbs. However the 9.5 needs axles,gears, diff etc. I guess my question is, is it worth it to build the 9.5 or do the gears and diff on the current 10 bolt? |
Why are you questioning this if you already have the 9.5 hybrid?
I just have the housing for the 9.5 it would need to completely built vs just gears/diff in the 10 bolt |
Originally Posted by vmaxpro
(Post 5436066)
Ive got a set of yukon 4.88's with less than 3k on them that ill make you a damn good deal on. Came out of my rockcrawler that had a 8.6" 10 bolt (zr2 blazer). Im swapping to a dana60 front and 14b full floater in the rear.
Hands down that 9.5" is way stronger, by the time you piece it together though youd probably be money ahead to just buy another complete one. Long term the 9.5 would be the way to go but be alot more expensive, gears for the 10bolt would get you back in business for alot cheaper. |
Not having shafts may be an issue since those have the smaller diameter at the wheel bearing.
Originally Posted by axisT6
(Post 5436200)
They can make a set for less than what 1 New OEM shaft used to cost. They have since been discontinued by GM |
(Post 5436302)
Not really. I sent Dutchmen Axles a factory Hybrid axle shaft from a 2006 SS.
Looks like yukon and dorman sell them no? I actually have the axles but ones bent. I had the housing checked for squareness and its just fine but the flange its self is bent. Not a clue how it happened? |
(Post 5436400)
Looks like yukon and dorman sell them no? I actually have the axles but ones bent. I had the housing checked for squareness and its just fine but the flange its self is bent. Not a clue how it happened? How can the tube be straight but the flange bent??? How was it checked for straightness??? Possibly wrecked??? |
