9.5" 14bolt limits? Discuss
Old Feb 15, 2011 | 04:14 AM
  #21
TURBHOE's Avatar
does anybody know the spline diameter of the 14bolt semi float? i thought i had it somewhere but i can't find it. i found the bearing diameter but not the spline. i would guess 1.5" at least but i can't seem to find any good info.
Old Feb 15, 2011 | 05:30 AM
  #22
TURBHOE's Avatar
there is so much bad info out there. most magazines seem to think its a 30 spline with the same diameter as the 10 bolt.
Old Feb 15, 2011 | 08:09 AM
  #23
DrX's Avatar
DrX
I just measured one of the stockers from mine - 36mm, just a tad under 1 7/16"
Old Feb 15, 2011 | 12:41 PM
  #24
Atomic's Avatar
I have a gauge for that
and 33 spline
Old Feb 15, 2011 | 01:44 PM
  #25
1FastBrick's Avatar
Custm2500's Rude Friend
If you couldnt find the correct info, You did not look hard enough. Before I built Pats I did a full break down and documented every thing I found out about the 14 bolt 9.5. I also linked all the build threads in my post
https://www.performancetrucks.net/fo...d.php?t=467473
If something specific is not listed Just ask I still have all the Parts!
Old Feb 15, 2011 | 02:03 PM
  #26
EVILGMC's Avatar
Originally Posted by 1Bear
I can’t speak as to the current rules, but as of 2009 any vehicle that ran 10.99 or quicker had to have c-clip eliminators if the rear end was a salisbury type that originally used c-clips.
I believe that if you have rear disk brakes, c-clips are ok.
Old Feb 15, 2011 | 04:13 PM
  #27
TURBHOE's Avatar
If you couldnt find the correct info, You did not look hard enough. Before I built Pats I did a full break down and documented every thing I founf out about the 14 bolt 9.5. I also linked all the build threads in my post
Well this damn site doesn't search numbers well. If at all half the time. But thanks for the link.
Old Feb 15, 2011 | 04:15 PM
  #28
TURBHOE's Avatar
I do know the disc will hold it in. I drove 20 miles slowly on mine when it broke. But it got to the point where it just over heated the brakes to fast so I had to tow it on a flat bed.
Old Feb 15, 2011 | 11:32 PM
  #29
TURBHOE's Avatar
thanks for an actual answer. went through all those threads and nothing about the spline size. i'm just trying to see if the 9.5 axle is any bigger or smaller than the 10.5 axle. looks like the spline outer is a touch smaller but the minor diameter is bigger. not sure on the rest of the axle. still looking.
i'm wondering if the suv's put a bigger strain on the axle shafts than leaf trucks. a leaf truck has the leaf rather close to the axle tube ends. so more force is applied to the outer bearing than by the housing. where as the suv's have coil springs closer to the housing with the links close to the wheel. so when the suv squats hard it seems it would have more of a tendacy to push the axle tubes down near the housing. putting a harder bind on the axle shafts inside. i understand the axle shaft holds the weight of the vehicle in a SF rear. but if the axle tubes are being bowed then the ends of the axle shaft near the diff would have a huge amount of strain.
with that being said, would it benifit the rear to put a girdle/brace underneath from one side to the other all welded up to keep the tubes from bending or will simply welding the tubes to the housing take care of most of this?
Old Feb 17, 2011 | 12:51 PM
  #30
TURBHOE's Avatar
No opinions on a truss?
