8.6 g80 broken... need help on what to do
Registered User
I've got a 2012 Silverado 1500 2wd with a 5.3. My truck has a 3.42 gear and a g80 locker. Anyway one of the spider gears shredded but something else inside not sure what it is broke. It looks like half of a block? Idk everything on the one side with the locker and those 3 bars going across all look good. I ordered new spider gears then realized today it's more then that. I was trying to avoid having to pull the diff out but I am assuming I have to now? Do anyone have any suggestions to fix it or should I just find a new diff? I'm on a tight budget what does anyone recommend? Thank you for the help! I'm still searching other threads right now also.
Mod with training wheels
Just pulled one out of my truck if you want a cheap replacement. I maintain they're not worth much more than the iron they're made out of, so I'd ship it to you for about that if you want a cheap swap-and-go replacement.
Word of caution though. When I popped the spider gears in mine back in the day, part of the debris got caught in the ring and pinion and ruined them as well. Better check that first.
Registered User
Registered User
70 TA
13
05-28-2004 11:54 PM
