6L90e in old platform...how to program TCM to VIN?
I have a 416 and I want to put a 6L90 behind it. I don't have the trans, pcm, or TCM yet (or harness for that matter). I heard that the 2015-2016 TCMs are more difficult to program. Can I just get an ol 58x LY6 PCM and any 6L90? I have HPT but beyond that I'm a bit confused.
Custm2500's Rude Friend
Some engine operating systems and transmission systems don't play nice if they are not matched. You get slipping or other issues that you can't tune out.
It's best to match the two if you can. If you can pull the Vin From the Trans operating system you can look on ACdelco tech connect site and check the calibration. you may be able to find out what engine operating system it was used with if you have the vin#.
Some times programing the base calibrations is best done with the OE software.
If you buy a new or refurbished Replacement ECU, it needs to be programed.
You need a bench harness to flash the modules by themselves if there not in a vehicle. They typically flash it through a DLC on the vehicle.
With a bench harness, they could flash the correct Matching OS.
