4th Gear Servo? Install
Old Oct 1, 2009 | 06:06 PM
HIPSI's Avatar
Default 4th Gear Servo? Install
Does anyone have a write up on how to install the 4th gear servo?
Thanks!
Old Oct 1, 2009 | 11:52 PM
andrew383's Avatar
traveling mod
have you changed out the vette servo yet??? the 4th is the outter most servo..pretty basic
Old Oct 2, 2009 | 09:35 AM
HIPSI's Avatar
I've changed the vet servo its on the side of the tranny.The 4th is behind the valve body.
Old Oct 2, 2009 | 09:51 AM
andrew383's Avatar
traveling mod
ummm no the 4th apply servo is in the same spot as the vette you already replaced.its what covers the 2nd apply servo.
Old Oct 2, 2009 | 10:31 AM
8.1 HD's Avatar
When I replace mine with the Sonnax super hold it replaced the stock cover..was the servo and cover all in one...I needed to remove the small heatshield for it to clear.
Old Oct 2, 2009 | 10:52 AM
KySilverado's Avatar
Believe you are thinking about the accumulator's which are internal to the transmission.
Servo's are on the side of the trans.
Old Oct 2, 2009 | 06:58 PM
HIPSI's Avatar
Hmmm so both servos go on the side? 1-2, 3-4
Old Oct 2, 2009 | 07:26 PM
andrew383's Avatar
traveling mod
YES,when you took the snap ring out and pulled the first piece out that was the 4th apply servo
Old Oct 3, 2009 | 06:00 PM
HIPSI's Avatar
Ha I got ya now.
Old Oct 5, 2009 | 06:47 PM
HIPSI's Avatar
How do you check band clearance for the servo pin?
