4l80e yoke
Where can i get one from? I couldn't find any on summit and some other places, im kinda in a hurry. When i change the yoke will a stock u-joint work or is there a special one that i need to use? Thanks
It's the same as a TH400 yoke,if you are running a stock driveshaft you can buy a u-joint with one side using the larger pattern of the TH400 and the other with the smaller stock pattern.Any driveline shop and most parts stores with knowledgable counter should be able to hook you up.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
jscherbs
Sep 30, 2015 07:54 AM
