4L80E Trouble
Old Dec 14, 2013 | 06:33 PM
Blackheart68's Avatar
Registered User
Angry 4L80E Trouble
I just rebuilt my 4L80E in my 02 Silverado 2500HD.. Put new TC in, (DAACO), new pump gears, etc.... Started it, shifts firm onto reverse, but seems to have only 2nd gear forward gear. This sounds like it is in limp mode. I did not change/replace the shift solenoids. I do not have access to a code reader and need this back on the road ASAP. I am thinking of dropping the valve body and checking all the valves and springs to ensure no one are stuck; all check ***** were replaced in the correct locations..... Any help will be greatly appreciated.
Old Dec 14, 2013 | 06:37 PM
Join the club. Misery loves company.Rebuilt mine and I have the same symptoms as you.
Old Dec 14, 2013 | 07:16 PM
Registered User
So you never figured anything out?
Old Dec 14, 2013 | 08:53 PM
Not yet, I pulled it and tore it Back down. Im gonna try some new electronics and do away with transgo's seporator plate.Was this your first build?
Old Dec 15, 2013 | 07:40 AM
Registered User
0n a 80e, yes. I was pulling a trailer home when it blew a seal (forget which piston), went into limp mode. Tranny was toast, weak when I bought it so I went ahead and rebuilt it. The front servo pin was broken, front planet had to be replaced, all new steels, etc.. I'm getting ready to go and warm the garage up and check the main wiring harness to ensure it is connected right. Had a friend helping me and he may not have connected it all the way.. It has to be electrical is what I am thinking; I tore it apart three times to figure out where the center support spacer went (yeah, I know) so the guts are solid and correct. If I cant correct it electrically I will drop the valve body next.
Old Dec 15, 2013 | 10:45 AM
Gadgetized's Avatar
What is the method for the tune? Segment swap or relay? When I first did mine I copied all the tables over and had similar symptoms. I later realized you need to do a segment swap as there are hidden tables that get swapped over. Just something to think about.
Old Dec 15, 2013 | 06:39 PM
kelsey_canard's Avatar
Join the broken 80e club
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
RustyD
May 23, 2016 07:04 PM
AdaMax
May 16, 2016 11:35 PM
turbo6c3
Oct 5, 2015 06:11 PM
jscherbs
Sep 30, 2015 07:54 AM
