4L80e Swap--Shift Linkage Too Long?
Quick question for those of you who have swapped a 4L80 into your trucks...I have mine installed in the truck and when I went to hook up the shifter cable to the actual shaft coming out of the trans the cable was too long. The transmission came with the shifter cable bracket that it clips into, but if I clip the cable into the bracket, the connector that goes on the shaft sticks out about an inch or so too long. Is there a way to adjust the cable to shorten it?
I think that is where my problem lies. My new trans didn't come with a NSS. I ordered a new one for it because the NSS on my 4L60 cracked when I took the connectors out of it. When my new NSS comes in, I will have to put it on the 4L80 and see if I still have the problem. Right now I have been just trying to line up the cable to the actual metal linkage arm that rotates. The NSS is not on there right now.
When end you get the new switch, don’t monkey with it. Install as is and see what happens.
