4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....
Old 12-20-2014, 07:42 PM
mdwatts11's Avatar
Holy huge pics! Nice work. What rebuild parts are you going with?
Old 12-20-2014, 11:51 PM
tgui's Avatar
Sorry, its how the pics come off my phone. Other forums resize and click to enlarge. I don't know why this forum doesn't. Is there a better way to post pics?
I am TOTALLY open to suggestions on parts. I'm shooting for a max of 600FtLbs (more like 500) since I'm going LS6 CAM and smallish turbo for early peak torque on my 5.3, but was thinking...
- Pretty much stock frictions and steels where needed. I keep hearing conflicting reviews on really aggressive frictions and steels holding heat too much. I'd love input here.
- Sonnax sure cure with that stupid expensive tool kit to drill things out.
- Transgo hd2 shift kit.
- Drill out the pump oil hole a bit.
- Sonnax fancy plastic check *****, wiring harness, 4x4 output shaft and misc I'll post when they arrive.
Should I do bearings? Should I just replace all frictions and steels?
Old 12-20-2014, 11:55 PM
tgui's Avatar
Originally Posted by Atomic
Forwards look a little rough....intermediates and directs look ok.
What makes you think that (serious, I'm learning)?
Here is a better pic. The material is a diff color than all the other frictions I found in the trans. And of course I appreciate the help!
Old 12-22-2014, 02:24 PM
tgui's Avatar
I resized pics to a more reasonable size. Sorry for the retarded huge images.
Old 12-28-2014, 09:47 PM
tgui's Avatar
Default Internal case damage
Uhhhh.... just noticed this bit chipped off inside. I found no such chunk when pulling apart. I assume the GM rebuild ran fine like this.
Do I have anything to worry about? I hope to god I don't need a new case...
Old 12-28-2014, 10:09 PM
tgui's Avatar
Not my case. Yup, missing something. Will my snap ring be ok without that bit of support?
Old 12-31-2014, 12:16 PM
James B.'s Avatar
I don't see that one broken tongue being a problem. When you put the snap-ring back in clock it so its gap is centered between the two supported ring slots.
Old 12-31-2014, 02:11 PM
tgui's Avatar
Thanks. I was thinking and hoping someone would say that. I've identified the HD snap ring from the transgo kit on WIT Trans for about $3.00. I'll slap that in to make things tougher On the cheap build after all.
Old 01-01-2015, 09:29 PM
tgui's Avatar
Dust cover for $19.00
Old 01-02-2015, 12:01 PM
tgui's Avatar
I got a good deal. $300 total for a Sonnax Sure Cure and the tool kit. Some guy on ebay had both sitting around, never used since he decided to just buy a new trans rather than rebuild his broken one.
The toolkit is $300 by itself, so I done good I think.
Also since I'm tearing everything apart I'm not going to get a Transgo HD2 kit. I'll more cheaply do the internal dual feed mod (free)
Quick Reply: 4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....
