4l80e questions
Some background, i picked up my 4l80e last year and had someone rebuild it. They also did the dual feed mod. I installed it and its ran good the past year. Put maybe 400 miles on it, did some other work to the truck so it was parked a lot.
The other day it felt like it wasn't engaging 3rd, and I also had the transgo sk 4l80e kit to put in. so I dropped the pan. Fluid smelt burnt, and clutch materials lined the pan. The magnet was missing from the pan, and when I removed the valve body I counted 5 nylon *****. According to the transgo kit it should be 8. I also found the seperator plate had a hole welded closed, appears to be for the dual feed mod.
My question is, the transgo sk 4l80e kit says that welded hole should be drilled to 1/8", does that still apply even with the dual feed mod? My other question is, are the nylon ***** known for disappearing? The seperator plate doesn't show much wear where the ***** sit.
Pretty sure the ***** are supposed to be stainless steel, not nylon. Nothing should be welded for the dual feed mod, but you do need holes in the VB and in the direct drum. Something sounds fishy...
The 4l80e sk from transgo had me drill one hole in the VB for a pressure relief valve, and one hole elsewhere. I'm also drilling the seperator plate as their instructions say.
Zacholcomb
Sep 3, 2015 06:14 PM
mz00516
Aug 23, 2015 12:19 PM
